Hi Geoff,
You could tie a tight loop around the far side of the cleat, as in this photoReply 14/08/2023 15:27:00
How do you deal with the lack of beckett on the CL257 to get the 2:1 pull?Reply 08/08/2023 17:29:00
The CL257 works pretty well. I fit them to all my boats. Essential piece of equipment for those of us who race in tidal estuaries or along the shore of places like Broadstairs. They save a whole lot of damage from those rocks that suddenly stick up a foot above the surrounding seabed. Reply 14/01/2022 14:39:00
Hi Pascal,
I have not heard of anyone fitting that.
The option was added to the Class Rules early on for those who regularly sail through areas of potentially shallow water, especially muddy estuaries where you can not see the depth.
An alternative is to lean back and uncleat the rudder downhaul whenever you think you may be at risk. With the rudder bolt at normal tightness the rudder will only tend to start to come up if you are planing.Reply 14/01/2022 12:21:00
Has anyone fitted a Clamcleat CL257 auto-release cleat to the rudder?
Any issue with doing this?Reply 14/01/2022 08:48:00
Pascal
