Home >> Technical >> Gel coat cracking off around deck ring aka mast pot
Hi Mike,
Sorry to hear that.
I suggest you contact your local dealer or RS Sailing Customer Support  ( mailto:[email protected] )  for advice on how to proceed.
15/10/2020 23:56:00
My boat has the pre-fitted deck ring but I keep getting gel coat flaking off around the edges of the pot. I'm pretty sure that it's just caused by a void between the laminate and the gel. BUT: how do I fix it?
What I would like to do is to pull out the existing mast pot , properly fix the gel coat then put in a new pot. The problem is that the mast pot won't move (it might with extreme force). Does anyone have any ideas on how to get the old pot out?
Thanks in advance
Mike
15/10/2020 13:46:00
MikeWay
