Home >> Technical >> Clew strap
Actually it’s the Laser that’s the oddity. Hoisting sail with a halyard is the norm. It’s worse for the sail to be flogging without being attached to a boom. To land on a lee shore, just undo the main sheet.
06/05/2018 03:17:00
david
Hi All Relatively new to the aero and rigging. Is it viable to use a traditional type clew strap to fasten to the boom instead of threading boom threw attached loop. Unless I'm doing something wrong seems odd to attach sail in this way prior to fix boom onto goose pin. As laser sailor used to fixing boom to sail once hoisted. Also on Lee shore landing would be easier to detach sail prior to landing . All suggestions welcomed Steve
05/05/2018 23:49:00
Steve P
