Lower Mast Mushroom
I see in the meeting notes that the function of this is to stop the tack strap & foot of the sail rising.
Why?
Doesn't the Cunningham / Downhaul do this also, duplication?
I ask because with my 9 & 7 rigs to rig for light wind conditions the halyard has to be backed off an inch or two to produce a flatter sail shape with no luff fold.
Fine until the wind picks up, when it means a return to shore to re-set the sail.
Wouldn't it be better to position the mushroom 1 to 2 inches higher such that the halyard can be hoisted fully up tight, and the tack strap horizontal with minimal tension on Cunningham / Downhaul; sufficient just to hold the stop knot in the gooseneck slot?
The sail shape can then be adjusted continuously from light wind flat shape through moderate wind full shape to strong wind flat and de-powering without having to return to shore to reset the halyard.
Also has anyone else had an instance of the tackstrap 'jumping the button' , rising above the mushroom, when easing sail controls to bear off onto a run?
This happened to me last Sunday, April 3rd in Bft 3 on the 7 rig. The rig made a sharp loud noise as though something had broken or come off. Would have been a return to shore to fix; as I was keeping station with 3 Lasers sailed by very good sailors at the time I declined and carried on.
Had the mushroom been higher up the mast there wouldn't have been the jumping and there would have been no question of returning to shore.
