Hi, Could anyone please offer me some advice-
I sailed my RS Aero 7 (1343) for the first time this weekend deliberately in very light winds to get used to the boat first (I am still a fairly new sailor).
I found that the top 2 adjustable batons did not bend easily to the correct side when I was gently taking and had to often pull hard on the boom to correct this.
I also had problems trying to remove long loose creases running vertical near the luff- I am aware that tightening the batons may reduce this problem, so I increased the tension just a little because I did not want to make it even harder to ‘flip’ them on a gentle tack.
I still appeared to have problems with the sail crease, even with loads of kicker (which I would not normally apply in light winds on a reach).
Should I accept that you have to tack fairly hard to ‘flip’ the batons and increase tension in them further or is this normal (this and the creases) or am I missing something.
Any advice would be much appreciated.
