Supplied with Aero S/N 1141 was a Halyard Tail of 5mm diameter.
I found when knotting the Halyard Tail & Halyard using the Rigging Guide double sheepshank that the knot would only pass through the mast head eye if pulled at right-angles with the mast lying horizontal.
With any load on the tail, and the mast erected there was no way it would turn the sharp right angle into the eye.
Trying to pass it back through the tail would catch.
The clear plastic end bindings of this dual fibre woven rope dropped off.
I don't know whether I was supplied a tail of a larger diameter, but if anyone else has had similar a problem they might be intersted in the solution I came up with together with the Grafham chandler:
The main halyard, the fine 2 mm rope, was threaded down the centre of the tail for the length that would be free of the mast head cleat, & stitched to the tail,
The ends of the tail were whipped with whipping twine,
A drop of glue (UHU) was put on the whipping knots,
Heat shrink sleeves were put over the whipping at both ends of the tail & also over the halyard to further protect the whipping and also provide a more graduated transition from thin halyard to the 5mm tail.
With that and some silicone spray on the bolt rope slot the sail went up smoothly with a lot less effort, the halyard tail turned through the eye OK, & cleated in the mast head cleat OK.
With this arrangement replacing the tail will be more involved; given the sharp bends through the eye that are under load it will be a wear item. Though how long it will be before the tail needs to be replaced I shall have to see. Carrying a spare already made up could be a an option.
Has anyone else had this problem and come up with an alternative solution?
Jonathan
