Fitting a new tiller extension
Steve Cockerill has done a good video on u tube that takes you through the process. Worth a look.
Reply 28/12/2019 21:38:00
Whizzer
I have a new carbon tiller extension for my Aero but I'm not sure how to fit the universal joint to it.
The UJ from RS (https://www.rssailingstore.com/Other-stock/S/Selden-Tiller-Extension-UJ-CA0015) has a small metal peg in the packet which can be seen in the photo on the above link but I don't know what that peg is for. There is also a rubber tube which I assume goes over the extension and UJ once it is fitted?
There is no screw hole in the carbon extension so presumably I need to drill a hole in the carbon to match the small screw hole in the rubber joint?
If anyone knows how to fit this correctly I'd appreciate some tips
Reply 28/12/2019 20:43:00
schweben
