RS Aero Boat Setup Tips - Top boat bimbles and tricks to get the best from your RS Aero
RS Aero Boat Setup Tips Top boat bimbles and tricks to get the best from your RS Aero
Thanks to the RYA Dinghy Racing Channel for producing this video. I hope it is of help to both new and existing RS Aero sailors to keep their RS Aeros performing efficiently, reliably and at their best, whilst staying true to the RS Aero Class ethos of keeping your boat simple, light, affordable and equal.
* Water bottle is 750ml * Correction - bungee on the downhaul take up, no bungee required on the outhaul take up if you minimise its length * Update - Stripped part of the 'Vang Secondary/control line' can now be 2.5mm minimum (updated from 3mm), to allow for stripping a 4mm rope
'Bimble' - A small job on you RS Aero to optimise it within Class Rules for efficiency and reliability of use. Often gives you a nice warm feeling of achievement, improvement and well being afterwards.
