I have done some shopping around as I was looking for an RS Aero double stacker and I wasn't convinced a standard 250 base would do the job. In case you don't know the trolley is a West Mersea 250. In discussions with them they suggested it will fit their 250 road base but also said depending on the base it may need slight modification for a perfect fit. In the end I went for one from Admiral Trailers in Honiton, Devon as they have already built a few single and double stackers specifically for the Aero trolley. Having got it home it sits perfectly on the trailer with lugs that go into the trolley frame rather than over the top. If you are looking at road trailers etc. I hope this helps! http://www.admiraltrailers.co.ukReply 22/09/2015 15:41:16
nigelrolfe
