Home >> Class Rules - Queries & Suggestions >> Outhaul Elastic
Outhaul Elastic
Thanks for this. Not so happy about pulling on the mainsheet block hanger. I use the vang hanger. I presume this is allowable?
01/08/2018 06:56:00
Thanks for your query.  This is considered allowable under the rule you quoted and we are glad to clarify this.  The shockcord should be tied to the hanger rope for the mainsheet blocks.
Have fun
David
20/07/2018 20:24:00
I would like to confirm the legality of having shock cord run through the clew cringe and forwards toward the mast.
Under rule C6.1.3M sailors are allowed to use shock cord to retract or remove slack from control lines. However this shock cord achieves this by moving the clew of the sail along the boom. The rule does not state that shock cord is allowed to aid changing the shape of the sail.
I have always assumed this shock cord to be illegal as its primary function is to aid release of the outhaul to change sail shape, not to remove slack in a control line. However more boats appear to be using the system which is why I am seeking clarification.
20/07/2018 16:25:00
Steve
