Home >> Transport & Storage >> laser trailer for RS Aero
M'y sail (boat) number is 1408. Boat is in "as new" condition. Very impatient to sail her Olivier
30/04/2016 09:31:21
Obo
Great!
Another pin in the map in a nice location!
...and perfect timing for this;
29/04/2016 21:50:49
On the way back home with my new aero :) . Trailer perfectly adapted to aero shape. Few adaptations required to adapt trailer to trolley. regards olivier
29/04/2016 20:11:04
Obo
I an happy to talk you through how I did it..
07/04/2016 20:03:24
haimark
Thank you for the very interesting suggestions. Will bring with me all the stuff to make the journey safe And Will take Time to make an appropriate modification at home. Thank you Olivier
07/04/2016 19:54:50
Obo
If you put the boat straight onto the trailer you will likely need to move those gunwale supports closer as the RS Aero is 1.4m wide.
From the top of the gunwale supports to bottom of the hull you need about 35cm clearance.
To remove the supports and go combo style is the neatest option if you have a trolley, if you can make it work. It looks like the trailer is wide enough to accommodate the RS Aero trolley as my (version 1) trolley is 1.48m wide to the very outside of the trolley wheel axel.
- I suggest you take lots of padding (carpet/foam/pipe lagging) in case you need to pad the bottom of the trailer or raise the gunwale supports a few cm.
- A webbing strop or padded rope would give you the option of tying it across the supports to suspend the boat from the supports if there is not enough depth clearance.
- Take lots of string to tie down
- tools to remove the supports if necessary.
- If you have a roof rack take it to have another option.
I am sure it will be possible if you have all those options.
07/04/2016 15:59:24
I have created a combi trailer exactly as suggested and it works well
04/04/2016 23:00:30
haimark
Yes doable with lashings of string. You might even be able to get someone to create a combi needs some metal and welding torch not urgent I would say
04/04/2016 18:37:19
Martin
Many thanks for the feed back. what about dismounting the support and fixing the trolley on the trailer?
04/04/2016 15:27:53
Obo
Looks like the gunwale supports are adjustable given the fixings on the axle. If you can loosen the nuts then they should be able to move to fit. However the trolley will need to go somewhere suggest roof rack!
03/04/2016 20:47:59
Martin
Peter
 here is a picture of my trailer with some dimensions. Could you let me know if it looks suitable to support an Aero?
i am up to make a long journey to purchase an Aero and i would like to make sure my trailer is adapted.
Thank you in advance
Best regards
olivier
03/04/2016 15:48:31
Obo
Peter, Thank you for you feed back Will take pictures during the week end and provide dimensions. Best regards olivier
30/03/2016 18:47:06
Obo
Olivier,
I think you will need to give more info;
Width, length, is it gunwale hung or supported underneath?
A picture may help.
An RS Aero is a little smaller and a lot lighter than a Laser so it is likely that it will work provided it is supported adequately. You may need to add padding to make up for any variance in shape.
29/03/2016 14:16:08
Hi all
can anybody tell me if the standard road laser trailer (not the combi one) can be used to support a rs areo?
thank you in advnce for your reply.
Regards
Olivier
26/03/2016 18:25:38
Obo
