Home >> Top Tips >> TopTip2020 #52 - Choosing Your Moment - Charlie Sansom, GBR
TopTips 2020 #52
by Charlie Sansom, GBR
Charlie Sansom of Bowmoor SC contemplates the balance between boat on boat tactics and playing the fleet as a whole;
' Choosing Your Moment
There are many great reasons to sail an RS Aero from its lightweight handling to its big fleet racing. When you are in the middle of a big fleet in the moment it can often seem overwhelming, with lots of boat on boat situations that can lead to winning or losing multiple places. Many of us instinctively choose to take a too aggressive approach towards other boats around us, not wanting to let someone go over you on the reach, or tack on you on the beat. In some situations, this is the right move and is definitely something you should be considering, however there are also some common situations where staying out of trouble can be your best option!
One classic example of this is on the beat to windward. If you are in a big fleet on port it is only a matter of time until you come across another RS Aero on starboard. Its at this point you have a choice. Often the gut reaction is to tack onto starboard with them - nail this and there is a good chance you will lee-bow them, allowing you to pull forward. However, this isn’t always the smartest move longer down the line - unless you have a significant speed advantage the boat you’ve just tacked on can hold you all the way to the port lay-line - somewhere you probably don’t want to be in a big fleet! Then there is also the possibility you don’t have the perfect tack, and they roll over the top of you. When you were approaching you had another option - to duck their transom. Yes, in the short term this would have put you behind them, but there was most likely a reason you were on port in the first place - whether to catch a shift or get a clean lane, had you have tacked you would be giving that up. In the longer-term ducking can often work in your favour too - you retain control of your options and next time you meet it will be you on starboard, where you will have the advantage.
Another example where we can show some restraint and choose our moment wisely is on a reach. When there is a big pack of boats behind you all you want to do is head up and fight for your slice of clean air. In some scenarios, this is the only option saving you from getting rolled by half the fleet. However, in others it can often pay to hold your nerve and stay low on the reach where possible (when I say low I mean best VMG). Before luffing, always consider whether the boat(s) you want to head up are an imminent threat and whether in reality they have enough speed to come over the top of you - if your sailing your own boat as fast as you can, this is unlikely to be the case. By staying low you are maintaining a good angle into the next mark, allowing you to come in with speed. Had you luffed even 10ËÅ¡, you may now find yourself running to the mark which is very slow. As well as this, if it’s a gybe mark, you are maintaining the inside line to the mark, allowing you to come out in front.
These are just a couple of examples of how not always taking the most aggressive approach to a situation can lead to you coming out on top. There are many other situations like this, but the moral of this is to always think about the end game of your manoeuvres - what will you achieve from doing this, and what could go wrong? If you go into every boat on boat situation with this mindset, you can make a more balanced judgement on what the best move is. '
20/05/2020 23:54:00
