Hi David,
Please can you advise -
Is the use of thimbles, as pictured, permitted under Class Rule C.6.1.3 (o) for over deck control line tails?
Performs the same function as a ring.
The benefit is that if ever they need adding, replacing or removing then that can be done easily, without the need to redo the splice on the continuous control line.
