This is what I did. Whether you choose to follow it is up to you.
- Carefully drill out to the retaining rivet for the plastic mast base plug (some people might have a retaining screw?)
- carefully tap out the plastic mast base plug, working around with a very large flat e.g. screwdriver at 120 degree rotation so as not to cam the plug in the mast, be patient and don't strike the mast itself lest you damage it;
- thoroughly clean all mating surfaces of inside of collar and mast where collar is to be glued. Use wire brush/60 grit sandpaper (go lightly) & then remove any grease with a rag with acetone;
- cut additional horizontal slots inside the collar using a Dremel tool cutting wheel (I used two wheels doubled together, and made a nice pattern, partly because I like patterns, and also to avoid lining up any of my slots next to other lest I create a stress fracture pattern. If you don't have a Dremel tool or but a cheap equivalent, ask a friend, or a even maybe a local model maker or jeweller, or choose to skip this step completely as possible overkill);
- lightly keyed the inside of the collar, including the recessed rims with 60 grit sandpaper;
- removed loose burrs with a wire brush; and
- cleaned again.
NOTE: If you've left the mast collar loose and rotating for too long, you might have worn away the inner surface and need to purchase a new replacement collar so that the collar is a tight and not a floppy fit which will be difficult to centre on the mast (I tried that once, it's not worth the effort).
To re-attach, I've:
- Made sure to work out the collar location beforehand, by sitting the mast in the mast step, allowing also for the height of the mast base plug;
- covered the mast etc (including outside of collar) in masking tape, everywhere you don't want Sikaflex to go, remember masking tape is cheap. Don't forget to leave bare the mast substrate where you tapered rims of Sikaflex will be;
- done a test "dry" fit to make sure the collar will slide over the masking tape, and be double certain where the final position will be (remember, there will be black Sikaflex obscuring any pencil marks, so better have an external reference like a notched stick handy);
- put several layers of disposable gloves on my hands, since I tend to get glue like Sikaflex everywhere, keep peeling a layer of gloves off as you go;
- applied a liberal amount of fresh marine Sikaflex 291 (black looks best, don't get the white) inside the collar and over the mast collar substrate;
- slid the collar up the mast into place. Don't worry if some of the Sikaflex gets left behind lower down the mast, that's why you used lots of masking tape - you just want to be sure that you've got as much Sikaflex pre-packed in the slots and grooves as you can, a little bit of waste is a small price for good adhesion;
- pushed additional Sikaflex up under the lower rim of collar (you can use some of the stuff off the masking tape that you left lower down the mast);
- cleaned up excess sikaflex with a rag / paper towels, and left a careful reinforcing taper rim of Sikaflex above and below the top and bottom rims of the collar (I used the straight edge of a credit card, although you could probably also use the blunt edge of a gloved finger);
- leave the Sikaflex to just start to set;
- carefully remove the masking tape alongside the taper rims of Sikaflex, and off the outside of the Collar (if you leave it too long, you might end up tearing the masking tape leaving a layer buried under the Sikaflex);
- remove the rest of the masking tape the next day;
- leave the mast in a damp spot for at least a week or more for the Sikaflex to cure (cure relies on moisture/humidity, if you're enjoying a dry summer, wrap in a a damp paper towel and plastic and leave in a sunny spot);
- tap the mast plug back in with a block of wood, not a plain hammer;
- drill a new hole in the plastic plug, through the existing hole in the mast base (remember, Selden warranty void if user drills additional holes in their mast, I believe. Don't even try to line up the old hole in the plastic plug, if you succeed 100% you need to buy a lottery ticket);
- fix new rivet to retain the mast plug (after all that tapping, you might not think it can move again, but yes it can, that's why the rivet is there in the first place).
When sailing, lubricate your collar and mast step, and make sure you don't get grit / dirt between the surfaces otherwise you're going to grind something away eventually, and if there's too much grit, somethings gotta give (better the Sikaflex in the collar than the mast step in the boat, but you've now done quite a bit to ensure the Sikaflex joint won't fail).
Happy Sailing!
Cheers,
Ron
