Home >> Technical >> Code color |
'We are pleased to say that now we can supply many of our older colours again and ship them worldwide, gelcoat Pigment is our solution! 20g of RS Pigment mixed into clear gelcoat will make up 400g of correct colour gelcoat. (5% mix ratio)
Only the pigment is supplied. Clear gelcoat and catalyst will need to be purchased separately. Due to some tricky and expensive hazards goods rules around shipping, in most case these items will need to be sourced locally.'
Which should make it easier to get an exact colour match than having some made up locally.
I hope this helps.
