My tiller is splitting along the top where the spiggot from the stock enters the tiller. I assume this is due to galvanic corrosion between the carbon tiller and the aluminium stock.
The only solution I can see would be to create a carbon tape / epoxy wrap around the split section. I fear this will eventually split.
Any advice greatfully received
MikeReply 15/05/2023 09:06:00
MikeWay
