Hi Megan
Thanks for the question. We have discussed this. I am sorry but this is not permitted. Allowing the use of Mylar strip or other materials would open up the possibility of abuse. If you are worried about wear then please use the retrofit deck ring. I have found that as long as you wash the mast and step regularly and avoid sand getting on them, then the wear is not bad.
Happy sailing
David
Reply03/05/2018 09:27:00
Can I use the Laser mast wear strip instead of the retrofit deck ring? I am reluctant to drill holes in the boat to do the ring installation and saw this as an option--
Reply23/04/2018 14:28:00
Megan_5280
